Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford Sierra 3.0 LX V6
Old 10-11-2012, 12:05 PM   #20
bollie
Fan#: 104626
What I Drive: Ford Sierra 3.0 LX V6
FF Reputation: 1 bollie Good Standing Member
This is going to be fun :) So here's a List Of parts a Buddy provided to get for Supercharger upgrade.
Supercharger
ARP Head and Rod Bolts.
Low Comp con rods and Pistons. Perfect Ratio is between 8.1 to 9.1 nothing lower and nothing higher
Upgrade valves, valve Guides, retainers ( Preferably High rev Dual Spring Retainers )
Skim Head ( Use only Metal Head gaskets. Nothing else )
Upgrade all Belts
Twin 4 barrel Holly Carb using supercharged setup
Upgraded Branch+ Exhausts
Upgraded Pullys allround.
Boost, Oil, Water temp gauges, Fuel Pressure Gauge as well
Boost Controller Switch
Try to get a Mallorey distributor. Perfect Timing for this setup will be at idle anything from 16 to 24deg
Make sure u get a decent fuel pressure regulator aswell
Recommendation - Is To bore out the block to 3.2, fit bigger lower compression pistons.
Above Supercharged setup should be good for around 300kw.
Am waiting for a TWIN T4 Application Or a Bigger Turbo Application
- Will keep you guys updated
bollie is offline
