Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Weird front end noises
Old 10-11-2012, 08:07 AM   #13
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,536, Level 22
Points: 1,536, Level: 22 Points: 1,536, Level: 22 Points: 1,536, Level: 22
Level Up 36% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
Originally Posted by 05focusST91 View Post
It could be a bad strut mount, make sure the nut in the middle under the hood on that side is tight
By strut mount, do you mean the bearing? It was ok when I inspected upon install though I did not replace it, maybe its worn. I will double check the strut nut (hehe) to make sure all is still tight (double hehe)
Originally Posted by Slammed_2.0 View Post
Side of fender well. It's all aluminum.
Strut mount will cause clunking
If the sway link is contacting the fender well wouldn't that mean the control arm bushings are bad and letting the control arm walk? I know I see a lot of BMW's do that
Jason SR230 2008 SE 5 speed
06Escape__________04 Superduty
03XR400R,plated____97 Escort
74Nova____________73 Nova Custom
71F100____________69 F100
Gettysburg150 is offline
