Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Key Fob Programming How-To
Old 10-11-2012, 01:31 AM   #16
SD_ZTW
SD_ZTW's Avatar
Fan#: 91209
What I Drive: 2003 White ZTW, D23 PZEV, ATX
FF Reputation: 2 SD_ZTW Good Standing Member
Originally Posted by longarm View Post
I have a 2007 ST. I tried the instructions listed above and it doesn't work. I turn my key on and off 4 times and in the off position with the key in the ignition, it chimes.
Then I push the lock button on a remote and the headlights flash and the door locks cycle. I then try it for a second remote and nothing. I can only get this done for one remote and it's frustrating. Any suggestions?
**EDIT** Never mind, I'm good. I dug up my owners manual and got r done. The sequence was different than what was listed here.
Hey Longarm,
Curious to hear what worked for your car. It will help the group. Also, just saw you said you switched 4 times but for the 2007 model, key needs to be turned 8 times...
Hey Crewzin,
You found that out. Yep, each time you change the code, you got to do all the ones you want to use at the same session. The key fobs not in
the car are no longer any good.
George
2003, ZTW, White wagon
ATX, 2.3L Duratech
SD_ZTW is offline
