Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Car won't start!
Old 10-10-2012, 07:55 PM   #7
rally864
Fan#: 91931
What I Drive: 2001 Red ZX3
Points 33, Level 1
Points: 33, Level: 1 Points: 33, Level: 1 Points: 33, Level: 1
Level Up 66% Completed
FF Reputation: 1 rally864 Good Standing Member
So i swapped ecu's tonight and got the car to fire up. The car will idle fine but as soon as you go to give it gas it will bobble and if you floor it will snub it self out and shut off. But if you roll into the throttle an feather it you can get it to rev to 4500 and it stops right there. I have have 3 of the vacuum bungs plugged on the intake manifold along with the tube that went to the brake booster. when its reving at 4500 rpm its only at half throttle if you go past that it will die.
rally864 is offline
