Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fuel spill when pumping gas
Old 10-10-2012, 03:05 PM   #8
Dark 007
Dark 007's Avatar
Fan#: 80502
What I Drive: 2001 marshall red LX
Points 571, Level 11
Points: 571, Level: 11 Points: 571, Level: 11 Points: 571, Level: 11
Level Up 43% Completed
Forum Activity 4%
FF Reputation: 1 Dark 007 Good Standing Member
Originally Posted by jdetzel View Post
If you force compressed air in then you will be forcing flammable fuel vapor back out - I do not think that is a good idea.
When you add fuel air needs to escape from the tank. To do this there is a vent tube that usually runs alongside the filler pipe. I think either the filler pipe is kinked or the vent tube is blocked.
I would call a Ford dealer service department or a good independent repair shop, describe what is happening and ask if they have heard of it before.
Now that you mentioned it could probably be clogged, because my fuel compartment cap locking machenisim (the one attached to the car's body) is broken. With that said, the filler pipe DOES get exposed to dirt, snow, leafs and even "spider webs". Thanks! I'll pass on forcing compressed air. And I'll shall contact my local Ford dealer service department, and get a second opinion from my mechanic.
Posted via iPhone using FF Mobile
Dark 007 is offline
