Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A good engine for a beginner to rebuild?
Old 10-10-2012, 02:13 PM   #26
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,786, Level 95
Points: 24,786, Level: 95 Points: 24,786, Level: 95 Points: 24,786, Level: 95
Level Up 44% Completed
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
Originally Posted by marbleheadjimmy View Post
In an effort to sound as noobish a possible, is it mandatory to remachine the block no matter what? Will every used block have to be remachined, or is it just down to whether or not the cylinders are scored/damaged/different bores? I don't want to go so cheap that all the effort goes for nought. Just curious if it's something that is a requirement no matter what the situation.
The manchine shop will check the cylinders for wear. All blocks are going to have a tapered wear= where the rings ride up & down in the cylinders, so more than others. To do it right you'd want the machine shop to figure out if it just needs a cleanup hone or bore & hone & oversize pistons & rings. Then you'd want them to resize the rods & hang & align the pistons unless you have floating pins. For a basic small block chevy kit it'll come w/ cast pistons,rings, bearings= rod/main, oil pump & a true roller chain. Then the machinst w/ say like= You need a .030 over pistons & .010 under mains or rods or both. Then you order the correct clearence sizes. Then the fun begins, grab a plastic gauge kit.
felixthecat is online now
