Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Transmission Shaking To/From 1st Gear
Old 10-10-2012, 01:18 PM   #130
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
Originally Posted by FrostedG View Post
^^ My rundown was intended to be informational. What I have stated are just the facts to the best of my recollection. I can count on one hand how many times this has occurred. I just haven't been able to reproduce the behavior at will - yet. I am confident that the issue will get fixed once the root cause of the problem is found. Until a root cause is found, people are going to waste a lot of time chasing symptoms. When there are no error codes being thrown, the next best course of action is to compile a list of the conditions under which the symptoms occur and try to infer what's going on from that.
I'd like nothing better than it to be something simple. But I just don't see how my transmission's behavior could be caused leaking transmission seals contaminating the clutch. If that were the case, I would expect this behavior to occur through a wide range of speed, RPMs, and my foot pressure on the accelerator. In my experience, that is not the case. The behavior has only occurred when road and traffic conditions have forced me to have a feather-light touch on the accelerator at very low speeds (under 10MPH).
But that's exactly what I'm saying. Every time I've gone to the dealership about this issue and tell them when it happens they just ignore it. They say "This is how it's supposed to drive" and ignore everything beyond that point.
The issue occurs mainly from 1-10mph, almost always from a stop, and almost always in first gear. Some of it is definitely clutch wear (I can feel a worn clutch), and some of it feels like the TCS. My guess is the clutch wear is for some reason registering as an issue with traction and the TCS is taking over to fix the issue. Who knows if that's the truth, but it would explain why turning off the TCS fixed the issue for most people for awhile.
But then it came back.
hotleadsingerguy is offline
