Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Car won't start!
Old 10-10-2012, 10:17 AM   #2
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 3,033, Level 33
Points: 3,033, Level: 33 Points: 3,033, Level: 33 Points: 3,033, Level: 33
Level Up 89% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 24 6SPD_soul Great Standing Member
You say you have spark since all the ignition components are new, but have you used a spark tester to verify that you're really getting spark during cranking? The pigtail/wiring harness that plugs into the coil pack is known to give people problems and of course a no start condition.
Your TPS sensor readings are probably typical, and the offline o2 sensor is a secondary problem. The fact that you got good compression test results (or any compression for that matter) re-inforces that the timing is probably correct.
I think you need to get 100% positive that you're getting spark, an adjustable spark tester is the sure fire way to know.
And welome to FF, hopefully we can be of some help.
6SPD_soul is offline
