Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Car dies when stopping
Old 10-10-2012, 05:20 AM   #19
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,317, Level 100
Points: 33,317, Level: 100 Points: 33,317, Level: 100 Points: 33,317, Level: 100
Forum Activity 38%
Originally Posted by BigMuthatrknG View Post
I'm pretty sure it would register a misfire wouldn't it.
Not always. A flashing CEL indicates a misfire on every rpm, but if it's a random misfire, then the computer doesn't always record that. To the ECU, it might not be a misfire because spark signal was sent, but it might not be strong enough to fire the charge.
No, the PCV vacuum line won't be collapsed when the engine is not running. It is engine vacuum that collapses the line.
A loose battery terminal will cause the conditions you've described, and that's where you should start. Remove the terminals, clean, replace. If you find corrosion: I recommend greasing the battery terminal after installing/tightening. That will prevent future corrosion.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
