Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - AC pulling outside air
Old 10-09-2012, 08:17 PM   #9
amc49
Fan#: 96610
Points 6,430, Level 52
Points: 6,430, Level: 52 Points: 6,430, Level: 52 Points: 6,430, Level: 52
Level Up 40% Completed
Forum Activity 100%
Just looked at the video. Exactly.
You pull the actuator motor and then with it plugged in hit button to see if the motor is rotating as it should, if not the motor needs changing. If motor working then door itself is stripped out at the axle portion.
Motor is the upper yellow and white wires on left.
amc49 is offline
