Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Valve cover gasket
Old 10-09-2012, 03:52 PM   #4
oshoguno
Fan#: 45853
What I Drive: 2012 Focus SE Hatchback
Points 857, Level 15
Points: 857, Level: 15 Points: 857, Level: 15 Points: 857, Level: 15
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 1 oshoguno Good Standing Member
The valve cover gasket leaks quite often, mostly near the front of the engine. It is pretty straight forward to replace, just make sure to clean the engine first so that no gunk from around the cover can fall into the head when you pull the cover off. There are threads about it, just do a search and you will find them.
oshoguno is offline
