Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fuel spill when pumping gas
Old 10-09-2012, 04:46 PM   #6
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
Points 310, Level 6
Points: 310, Level: 6 Points: 310, Level: 6 Points: 310, Level: 6
Level Up 20% Completed
FF Reputation: 1 jdetzel Good Standing Member
Originally Posted by Dark 007 View Post
That sounds like it could be the problem, but i'm interested on what could be clogging it. Dirt perhaps?!?... I shall try unclogging it with compressed air.
Posted via iPhone using FF Mobile
If you force compressed air in then you will be forcing flammable fuel vapor back out - I do not think that is a good idea.
When you add fuel air needs to escape from the tank. To do this there is a vent tube that usually runs alongside the filler pipe. I think either the filler pipe is kinked or the vent tube is blocked.
I would call a Ford dealer service department or a good independent repair shop, describe what is happening and ask if they have heard of it before.
jdetzel is offline
