Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - RPM fluctuation at steady speed with DCT?
Old 10-09-2012, 10:07 AM   #4
mp223
Fan#: 104161
What I Drive: 2012 Focus SEL
Points 266, Level 5
Points: 266, Level: 5 Points: 266, Level: 5 Points: 266, Level: 5
Level Up 32% Completed
FF Reputation: 0 mp223 Newbie
Originally Posted by foh-kuhs View Post
I've noticed it going up a gentle incline at steady speed. Tach will waver a bit and you can feel it surge. I always attributed it to the engine and not the DCT but who knows.
Well in theory, traveling at a steady speed on flat ground, the engine RPM and vehicular speed should increase or decrease linearly with consideration to gear. There "should" be no room for variations between the two.
I'm reading about something Ford calls "micro-slip." Maybe thats it?
http://www.dctfacts.com/latest-news/...ch-Europe.aspx
Also new is the concept of clutch micro-slip, which helps reduce fuel consumption by allowing the engine to run at lower rpm, helping dampen the noise and vibration that would normally occur at such low engine speeds. Micro-slip also helps make gear shifts smoother, says Ford.
Originally Posted by feta_mgp View Post
I don't notice this SO much, but what I have noticed since getting the 12b37 update applied to my DCT is that when using cruise control I'll have slight hiccups. The RPMs will surge often less than 100, but it's as if the car has lost power for that SPLIT second, then regains it's composure and all is well for another 20-30 seconds. I have since stopped using cruise control because it bothers/worries me. My dealership did nothing for me.
I still notice it even when not using cruise control.
mp223 is offline
