Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - who here is running a capacitor?
Old 10-09-2012, 07:44 AM   #23
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
What I Drive: 01 cd silver 3 door ztec
Points 7,680, Level 58
Points: 7,680, Level: 58 Points: 7,680, Level: 58 Points: 7,680, Level: 58
Level Up 65% Completed
FF Reputation: 2 sgtsmasher Good Standing Member
Originally Posted by 02Zetechse View Post
the big 3 is actually quite simple as you do not replace the old wires , you simply add larger wires . the ground for the car flows the path of least resistance .
some things to check would also be adding a larger power wire from the alt to the battery, check battery and alternator state of health .
If your looking for a good read (very technical) http://www.newtiburon.com/forums/showthread.php?t=144225 ... It has quite a bit of hardcore information .
I hope you dont think Im trying to bash/flame you , I am just trying to provide a valid argument for my view on the subject .
Cheers
Edit : also what kind of amplifier are you using and at what Ohm load?
i know your not trying to burn or flame me, you were trying to get your point across that caps are not the solution to an existing problem. as far as the tech stuff i know you read a few post back about the blah blah i dont get technical stuff im running an amazon amp 4000w Pyle at what ohms? i have no idea i had it bridged, to a Pyle 15" sub which i think they said it was like 3000w max...
Hatch Nation #72
Call Me BRANDO COMMANDO
sgtsmasher is offline
