Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Smoke coming from 2002 Zetec by dipstick
Old 10-09-2012, 01:03 AM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,287, Level 93
Points: 23,287, Level: 93 Points: 23,287, Level: 93 Points: 23,287, Level: 93
Level Up 94% Completed
Forum Activity 13%
Activity: 13% Activity: 13% Activity: 13%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Being the exhaust in near that area and a source of heat, enough heat to 'burn' (not combust/ignite) oil; odds are it's oil leaking onto the exhaust.
The oil in the pan does not reach the level of the entry point of the dipstick tube into the engine block.
But oil splashing around could make it's way past the O-ring seal on the bottom of the dipstick tube.
If that's the area you think is the problem then I would take the dipstick tube out and inspect the O-ring for damage.
Simply remove the 1 retaining bolt on the cylinder head, twist and pull gently on the tube. It should come out relatively easy.
Do be sure first that there is no debris that will fall into the oil.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
