Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Zetec valve adjustment....
Old 10-08-2012, 09:30 PM   #7
amc49
Fan#: 96610
Points 6,545, Level 52
Points: 6,545, Level: 52 Points: 6,545, Level: 52 Points: 6,545, Level: 52
Level Up 98% Completed
Forum Activity 80%
Activity: 80% Activity: 80% Activity: 80%
That's fine. The intakes hardly wear at all, when I pull them down I simply lap them a bit and throw them back together. The tappets or shims will stay the same. The exhausts however wear quite a bit, as they do they will close up clearances. If I pull head down I recut exhaust valves and seats. I tell the grinding guy not to cut stem tips, then instead of changing tappets or shims (I have one of each) I grind the valve tip to set up the clearance.
amc49 is offline
