Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - common problems with the Duratec?
Old 10-08-2012, 07:56 PM   #66
Fan#: 93397
What I Drive: 2007 Focus SE 4dr Dark Shadow Gray
Points 675, Level 13
Points: 675, Level: 13 Points: 675, Level: 13 Points: 675, Level: 13
Level Up 50% Completed
FF Reputation: 1 WSkobra Good Standing Member
Originally Posted by boardgeneration View Post
Is the passenger side mount the only one with fluid in it? Also my dog bone looks like the small bushing only has rubber on two sides. I would have thought it would be rubber all the way around the metal insert that the bolt runs through.
I'll be replacing those two bushings with massive poly ones and press em into my stock dog bone. As for the driver side, how are the poly ones. I don't want unnecessary vibration but I don't want to be replacing these again.
Yes the passenger side is the only one with oil in it. As far as the dog bone polyurethane inserts, you don't have to have them pressed in. I managed to press them in by hand using my 230lbs of weight. You have to use a specific type of grease that acts as a glue that will hold the inserts in place. Otherwise without the grease the large insert will keep sliding out.
WSkobra is offline
