Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2005 ZX3 "turns off" when braking from high speed
Old 10-08-2012, 06:01 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,421, Level 29
Points: 2,421, Level: 29 Points: 2,421, Level: 29 Points: 2,421, Level: 29
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 9%
Buy-Sell-Trade Rating: (3)
When the engine stalls, you lose engine vacuum that helps power your brakes and steering. The oil pressure and battery light coming on is normal since the engine is off. That part is simple to explain.
If the engine stalls suddenly only during the application of the brakes, check the wiring in the rear hatch between the hatch lid and body for shorts. Lots of info about it on here. There may be an electrical short.
If the engine stumbles and then stalls, check for a large vacuum leak in the induction system after the MAF sensor.
Get the DTC (check engine light) code read as soon as possible as that may give you a clue as to the problem.
BC_ZX3 is offline
