Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to remove petrol door cover ?
Old 10-08-2012, 10:51 AM   #11
feta_mgp
feta_mgp's Avatar
Fan#: 88210
What I Drive: 2012 SGM Focus SEL
Points 3,601, Level 37
Points: 3,601, Level: 37 Points: 3,601, Level: 37 Points: 3,601, Level: 37
Level Up 68% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 7 feta_mgp Good Standing Member
Originally Posted by jdetzel View Post
Sorry to not answer your question about removing the fuel door. Is yours round or more square shaped?
The paint code from the VIN tag will give the shop the formula to mix the same color. But it is still different paint. It you took two of the same cars, same color with different production dates and swapped body parts (a fender or a door) there is a good chance that a visible difference in the color tint would exist.
It is not a bad idea to after mixing the paint to spray a test panel and match it to the existing paint on the vehicle. The paint shop is just trying to insure the customer gets a good product that they will be satisfied with. To advise someone not to comply with the shops request it really not being very helpful.
But to ask the customer to remove a part of the car is also not being very helpful. We have specialized body shops, collision repair shops, and mechanics for a reason. If everyone was so good with a wrench and knew exactly how to do these things, we wouldn't need these shops. A body shop should have workers competent enough to remove the door themselves or just use the whole car as a reference to match the paint, or use a specific area to match the area they're painting, and be competent enough to blend it where it meets another panel with slightly off color.
Note that I say *SHOULD* as Fine Line Collision here in Vero Beach, FL couldn't get my last car right after 4 tries.
Once upon a time I had:
2012 SGM SEL Sedan Job 1 BD 6/2011
FSWERKS Cool-Flo w/ ITG Filter | FSWERKS Stealth Exhaust | 17x7.5 Axis Sport XMX Graphite wheels | Eibach Sportlines on Ti Handling Pkg bits
feta_mgp is offline
