Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Car seems faster with ethanol
Old 10-08-2012, 10:21 AM   #12
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 5,996, Level 50
Points: 5,996, Level: 50 Points: 5,996, Level: 50 Points: 5,996, Level: 50
Level Up 23% Completed
FF Reputation: 1 raptor1956 Good Standing Member
Originally Posted by IH84DZ View Post
If you are running more than E10 in a gasoline vehicle you are harming the planet. The engine control system is often not able to reach the ideal stoichiometric ratio with trim adjustments and will enter open loop. This will affect HC, CO and NOx emissions and catalyst efficiency will be reduced.
Save the planet. Run the right damn fuel in your car. If not, you have chosen to pollute our rivers and streams, kill polar bears and warm the globe!!!!!! You are evil and should feel responsible for all the seemingly negative climate related events henceforth. You should register as a Republican and smoke a cigar with your rich, big oil corporate white collar cronies.
If it's flex fuel, yes I'm sure it feels a tad more peppy. Once the car realizes it is running ethanol it can apply a slightly more agressive ignition timing due to the detonation resistance of ethanol.
More than that ... ethanol brings with it additional oxygen so it WILL enable the car to produce more power. The downside is lower mileage as ethanol contains about 1/3 less energy per gallon.
The 2012 FF is a flex fuel vehicle, at least the ones beginning with job 2, and the engine will adjust the fuel/air ratio and all other parameters as needed and since ethanol is a cleaner fuel it will NOT be hurting the planet!
Brian
2012 FF Ti HB Sonic Blue, Built 5/7/12, 401A + Parking Technology Package and MFT w/NAV 3.0.2 -> 3.2.2 -> 3.5.1 -> 3.6.2
raptor1956 is offline
