Ford Sierra 3.0 LX V6
6K views 20 replies 11 participants last post by  bluebullet
#1 · (Edited)
Hi Everyone , iv just registered & here goes, Im From South Africa i and recently Iv purchased a Ford Sierra 3.0 LX V6 , im seeking guidance in the sense of:
1 - Purchasing a Turbo
2 - installing a turbo
3 - Internal Motor Adjustments (Turbo Application)
Currently im busy with the body works. Would like to upload some pics
#20 ·
This is going to be fun :) So here's a List Of parts a Buddy provided to get for Supercharger upgrade.
· Supercharger
· ARP Head and Rod Bolts.
· Low Comp con rods and Pistons. Perfect Ratio is between 8.1 to 9.1 nothing lower and nothing higher
· Upgrade valves, valve Guides, retainers ( Preferably High rev Dual Spring Retainers )
· Skim Head ( Use only Metal Head gaskets. Nothing else )
· Upgrade all Belts
· Twin 4 barrel Holly Carb using supercharged setup
· Upgraded Branch+ Exhausts
· Upgraded Pullys allround.
· Boost, Oil, Water temp gauges, Fuel Pressure Gauge as well
· Boost Controller Switch
· Try to get a Mallorey distributor. Perfect Timing for this setup will be at idle anything from 16 to 24deg
· Make sure u get a decent fuel pressure regulator aswell
Recommendation - Is To bore out the block to 3.2, fit bigger lower compression pistons.
Above Supercharged setup should be good for around 300kw.
Am waiting for a TWIN T4 Application Or a Bigger Turbo Application
- Will keep you guys updated
