Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear Alignment
Thread: Rear Alignment
Old 10-08-2012, 07:03 AM   #5
BetaDnB
Rubber Side Down
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2016 Race Red ST1
Points 3,025, Level 33
Points: 3,025, Level: 33 Points: 3,025, Level: 33 Points: 3,025, Level: 33
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
Forum Activity 5%
FF Reputation: 17 BetaDnB Great Standing Member
Just wondering how you're judging the toe is off with the naked eye. The camber you're seeing is probably the negative camber you should have in the rear. Your camber shouldn't be 0. The only reason you should need an alignment in the rear this early is if you've completely beat the hell out of your car on extremely rough roads or ebrake drifted your rear end in to a curb. Also, why are you only changing the rear tires? Do you not rotate then stick the rears on the front once the front wears down?
Current- 2016 Race Red Focus ST1
Traded In - Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
Last edited by BetaDnB; 10-08-2012 at 10:15 AM. Reason: grammatically incorrect use of the word "you're"
BetaDnB is offline
