Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Hid not working on--
Old 10-08-2012, 01:13 AM   #10
Flying56eagle
Flying56eagle's Avatar
Fan#: 69819
What I Drive: 2009 RED SANGRIA METALIC SES COUPE
Points 3,843, Level 39
Points: 3,843, Level: 39 Points: 3,843, Level: 39 Points: 3,843, Level: 39
Level Up 29% Completed
FF Reputation: 11 Flying56eagle Great Standing Member
Originally Posted by Baldurs390 View Post
check and see if you have water in any of the connection on the lights and ballast
no water
Originally Posted by badazz2010focus View Post
they a high low kit?
yes that is why the are called BI exon
Originally Posted by JDBug182 View Post
Not familiar with the bi setup..... But are you running a fused relay from the battery?
No I'm not, that is what I was woundering, because I blow the fuse every time, if I install the facktory set back everything works fine, when I install the hid. everything works also ecept the brights
Originally Posted by bmiglio72 View Post
I used to have a bi xenon set....have the brights ever worked because if not its most likely the hi lo control box is defective so just send it back
this is my second set..
most people dont run hi/lows because they lows are plenty unless you live out in the middle of cow country LOL!
in pa for the inspection you have to have high and low beam switch working.
Originally Posted by klrfoucs View Post
i have a set of hid's that i havent really seen elsewhere, from what i understand bi xenon have 2 filaments, mine only have a single that is about an 1in and a half long maybe a tad more but they magnetically pull back in the h13 socket so it gets higher and wider, terrible lighting on my high beams thought, recently my passenger side light has been turning yellow so i think my ballast is about to go and on occasion one or the other doesnt turn on but turn off and on again and they both work?
glad you found your problem..
I used to have the same thing. I'm sorry to say I really doubt that is a fixable problem. I think it may be the ballast taking a dump. I also have the thought it might be the high low control box in the wiring because both of your lights are acting up.
it never worked for the start. second set
Originally Posted by crice8 View Post
Sounds like there is a short somewhere in your Hid system. Hard to say where exactly. maybe in the ballast maybe just in a wire.
again second set.. So no has a fuse system I gather from the responses, and everyone seams to just buy the single cheaper one filament hids, and never use there brights anymore? am I missing something here. Maybe I will just put my factory system back in.
Stay Focused
Some say I give them hell, I just tell them the truth , They think it's hell
Flying56eagle is offline
