Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sputtering at Idle loss of low end power
Old 10-07-2012, 07:11 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,461, Level 100
Points: 32,461, Level: 100 Points: 32,461, Level: 100 Points: 32,461, Level: 100
Forum Activity 46%
Activity: 46% Activity: 46% Activity: 46%
O2 sensor codes can indicate other problems depending on what the code was. Typically the sensors themselves last about 100k miles, but there's no sense in replacing it if it's not the actual cause of the problem.
Check your air intake for leaks and your vacuum lines first.
Your symptoms could be a sign of a sluggish TPS, but let's wait on that one since it won't throw a code indicating it's bad- it never will, so it's sort of process of elimination for that one.
Try tune-up items first. You should also pull the plugs, clean, re-gap, and reinstall. I'd replace the wires if you have lifetime warranty wires- if not, forget it for now. Fuel filter, air filter, clean the MAF, and that should be about it. That might solve all your problems.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
