Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - High Temperature Warning
Old 10-07-2012, 07:08 PM   #26
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,183, Level 72
Points: 12,183, Level: 72 Points: 12,183, Level: 72 Points: 12,183, Level: 72
Level Up 34% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
Buy-Sell-Trade Rating: (3)
Originally Posted by paul21 View Post
The temperature gauge is hardly a gauge at all. It's programmed to show actual below ~160F? (not sure the exact number but it's not the actual normal temp) and then it just sits in the middle all the time after that. It won't go above until the actual temp crosses a threshold value.
My 99 explorer had an oil pressure "gauge" that was operated off a simple switch. It was either 0 or 50%.
The gauge never shows the actual temperature. It sticks at cold for a while then jumps to somewhere below the middle, then sticks to the middle unless its over heating. By that point it might be too late. However at that point it might be too late.
The car knows what the actual temperature of the coolant is, but the gauge is just for show. If you were to play with the test mode you can watch the actual temperature reading from the coolant temperature sensor.
suss6052 is online now
