Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Where is the best Grounding spot in hatches?
Old 10-07-2012, 10:12 AM   #7
Jeffrosilver07
Jeffrosilver07's Avatar
Fan#: 104592
What I Drive: 2007 Silver Focus SE
Points 559, Level 11
Points: 559, Level: 11 Points: 559, Level: 11 Points: 559, Level: 11
Level Up 18% Completed
FF Reputation: 3 Jeffrosilver07 Good Standing Member
I had an 02 SVT and now have a 07 SE, I used the same grounding bolt in both cars and had very good success with it. I used an impact gun to remove the back seat back bolts and then a dremel tool to get rid of the paint. Sandwiched the ground between the metal floor and the seat back and put the bolt back in. I have a 0 gauge ground so the ring terminal is pretty big and was able to fit around the bolt. Neither cars had/have any noise issues from placing the ground in that location. Hope this helps.
Jeffrosilver07 is offline
