Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2002 zts 5-speed will only go in reverse when engine is off????? Help?! Please.
Old 10-07-2012, 05:56 AM   #8
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 527, Level 10
Points: 527, Level: 10 Points: 527, Level: 10 Points: 527, Level: 10
Level Up 54% Completed
FF Reputation: 17 nilskje Great Standing Member
If it works fine with engine off, its most likely the clutch not disengaging properly,or the pilot bearing dry, making the input shaft rotate a little, most commonly seen on IB-5 gearboxes (the one without a drain plug), It has no syncro on reverse, unlike the MTX-75.
Try putting in 1 gear and then take it to reverse, keeping the clutch pressed. Mine has been like that for a long time..
nilskje is offline
