Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - My 08 SES w/ Easy to Do Mods
Old 10-06-2012, 10:45 PM   #24
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
Points 4,931, Level 44
Points: 4,931, Level: 44 Points: 4,931, Level: 44 Points: 4,931, Level: 44
Level Up 91% Completed
FF Reputation: 5 DarderSauce Good Standing Member
Originally Posted by mac.mogul View Post
I'd get rid of those LED reverse lights in a hurry, those projector style bulbs do not offer visibility from an angle. You should use an LED bulb that utilizes the reflector to maximze visibility from all angles. If you're in an accident and someone sees your projector style bulbs, that may put you at fault depending on local authorities.
I disagree. The difference from what you've got compared to stock is much nicer, seeing from an angle is not an issue. I haven't had any problems with mine.... Other than they seem to interfere a bit with the radio whenever I shift into reverse
If you can't wear it out, burn it off
DarderSauce is offline
