Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - For Sale: 2009 Focus coupe
Old 10-06-2012, 07:12 PM   #1
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
Located in Kansas City, KS
2009 Focus SE Coupe 5spd in Vista Blue
Asking $9000 as is, $8000 returned mostly to stock
84k miles (mostly highway for work use last year), has been driven very rarely since dec '11
maintenance kept up to date, oil changed every 3-4k with valvoline syn 5w20 and motorcraft filter
tires have maybe 2k miles on them. michelin tires, uniroyal tigerpaw gtz 215/45/17 on 17x7.5 focal F01 wheels (black with red accents)
mods list:
blue laminex on head and fog lights.
6k 35w ddm tuning hid's in head/fogs
apc hyper white bulbs in front turn/running lights
resonator removed from intake and holes cut in bottom of airbox, k&n drop in filter.
black massive strut bar
limited purple massive rear toe and camber arms
F2 2.5" catback exhaust
H&R springs on monroe sensatrac dampers (rears will be replaced shortly under warranty)
taillights tinted with niteshade (still can see them clearly)
20% lumar tint on all windows.
close to color matched vinyl visor on front (can remove or redo as it's a little torn up from driving.
has factory trunk spoiler (plasti-dipped black)
rear focus emblem dipped black
steeda short throw shifter with saleen shift knob.
dash kit for aftermarket headunit painted blue (as well as a few other int panels)
push button for starter and custom ign setup. keysense activates acc and ign, cuts off when key is removed
viper 5901 remote start, keyless, security (lcd remote has damaged screen, but still works. one way remote is in good working order)
wig wag lights on switch (front turns and rear stop/reverse lights)
blue led's in vents on switch.
focal 6.5 coax in front doors
kenwood excelon 6.5 coax in rear sides.
will have 4 ch and sub rca's ran as well as 4 gauge power and ground if desired
neg battery terminal upgraded for larger ground wires
block to ground/batt to ground wires upgraded to 4 gauge.
8 gauge throttle body ground
Now for the couple bad things about it.
there are a couple scratches on the right corner of the front bumper.
couple spots on right corner of rear bumper where paint is clean off.
pass rocker panel near front of door had a jack slip and dented the panel. no paint damage or rust, just dented.
For returning to "mostly stock" I can leave on the wheels, exhaust and head/taillights.
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
