Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New (to me) SVT in San Diego
Old 10-06-2012, 05:41 PM   #9
SD_Rider
SD_Rider's Avatar
Fan#: 103846
What I Drive: 2002 Blue SVT
FF Reputation: 1 SD_Rider Good Standing Member
Originally Posted by focuztyle View Post
So what I have seen done is that you want to mark with white out BEFORE you move the cam gears out of position the valve cover and the cam gear with a line so that you can line those two up again when you are putting it bak together but it kinda sounds like you already moved them outta position though ....
No. I haven't removed the timing belt. I think that it's out of time. I was told that the first owner changed the timing belt....it may not have been done correctly.
I want to insure that the timing is tits before I put the new belt and pulleys on. I want to be 110% sure everything is correct, so I don't have to do this job twice.
I picked up a new tensioner today. After looking at the new one, the outer lip was also missing. The belt looks new, so I'm not too worried about that.
2002 Ford Focus SVT 125k
1996 Nissan Pathfinder 250k
2001 Suzuki Marauder VZ800 9.5k
SD_Rider is offline
