Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Odd Oil issue
Thread: Odd Oil issue
Old 10-06-2012, 09:34 AM   #12
Jgrove998
Boost Addict
Jgrove998's Avatar
Fan#: 45311
What I Drive: 2004 SVT Turbo
Points 6,319, Level 51
Points: 6,319, Level: 51 Points: 6,319, Level: 51 Points: 6,319, Level: 51
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 25 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Air needs to "flow" through the engine for the PCV valve (located behind the intake manifold) to work. If I'm understanding your setup right the valve cover is vented but the PCV valve is stuck closed because there is no vacuum to open it.
Here are some options:
1a)Run a hose from the valve cover to the ground
1b)Pull the intake manifold, pop out the PCV valve, cut the bottom off carefully, remove guts, re-install valve body (its now open all the time because you removed the guts) and run hose to ground, close off intake manifold port (Sporadic did this on his first turbo build, pictures in that thread)
Or you could setup a catch can: (Must be vented!)
2a) Run hose from valve cover to catch can
2b) Gut the PCV valve (same as above), run hose to catch can
2c) Throw that little filter on the top of the catch can so air can escape and the nasty stuff stays in the catch can
I think that would help your oil issues, plus the balance shaft delete for more oil capacity.
2004 SVT: bewst'd!
2013 Escape SEL 2.0 Ecoboost 4WD
2004 F350 6.8L V10 4x4
1986 XR4Ti 2.3L Turbo, 15 psi
Jgrove998 is offline
