Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New (to me) SVT in San Diego
Old 10-06-2012, 04:20 AM   #7
SD_Rider
SD_Rider's Avatar
Fan#: 103846
What I Drive: 2002 Blue SVT
FF Reputation: 1 SD_Rider Good Standing Member
Got it all tore down tonight. I was shocked and amazed at a few things.
-The water pump pulley nuts were hand tight....didn't need a socket to remove them.
-The Tensioner was broken.
-I do not have a 'lower splash cover'.
-The previous abuser REALLY liked anti-sieze on his plugs.
-Removing the crank pulley was the hardest...had to use the starter and breaker bar trick. My impact wrench wouldn't do the job.
Big question: How am I sure that I'm at TDC and not BDC? I can see Piston 1 up, but I also see Piston 4 up. I had this issue once in my Firebird and overheated the engine. I just want to be sure I'm doing it correctly.
I put the pin in and rotate the engine. It hits, but if I rotate it backwards a bit, it hits again. Nowhere in this span do the cams lineup for the bar to slip in both slots.
2002 Ford Focus SVT 125k
1996 Nissan Pathfinder 250k
2001 Suzuki Marauder VZ800 9.5k
SD_Rider is offline
