Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Putting a cone filter on stock intake
Old 10-06-2012, 02:10 AM   #59
frednumber15
frednumber15's Avatar
Fan#: 83585
What I Drive: 2003 2dr ZX3
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
FF Reputation: 5 frednumber15 Good Standing Member
I got a 5% (2 mpg) gain from installing a similar cone filter in the same place....but you'd want one with a bellmouth molded inside....
http://www.profblairandassociates.co...mouth_Sept.pdf
The OEM intake is restrictive even if you have the resonator removed. The OEM airbox has a straight pipe intake.
Intake temps as measured from the IAT thru a ScanGauge are only a few degrees above ambient.
* you need that piece of foam in your box in the upper left corner to filter the intake air for the PCV system?
Originally Posted by Leenwerd43 View Post
just got one from auto zone, im wanting to make/ buy a heat shield for it and also put a tube where the old resonator was and put it down into the fender to bring more cold air into it
2003 2dr ZX3 2.0 L Zetec auto 205/50/16s
...and I am unanimous in that position.
frednumber15 is offline
