Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Valentine One
Thread: Valentine One
Old 10-05-2012, 10:15 PM   #29
Ratskrad
Fan#: 93063
What I Drive: 2012 Sterling Gray Focus SE
Points 148, Level 2
Points: 148, Level: 2 Points: 148, Level: 2 Points: 148, Level: 2
Level Up 96% Completed
FF Reputation: 1 Ratskrad Good Standing Member
Re: Valentine One
Hi Devvy, it just needs to be grabbed firmly at the top and pulled gently, rocking side to side. It will start to separate from the pillar and you will see/feel the clips. Don't pull the cover off - just pull the top away from the pillar about 1", enough to get a hook through to pull your wire. You can then route your wire under the air bag and down the pillar. The side trim on the inside of the door/pillar interface easily pulls back and you can retrieve your cable. Once you got the cable, you can route to the fuse box.
I hope its clear - if not I will send some photos. Good luck.
Ratskrad is offline
