Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - not so stock transmission issues
Old 10-05-2012, 08:32 PM   #9
Minchkin
Minchkin's Avatar
Fan#: 92792
What I Drive: 2009 Black SES Coupe
Points 1,070, Level 17
Points: 1,070, Level: 17 Points: 1,070, Level: 17 Points: 1,070, Level: 17
Level Up 70% Completed
FF Reputation: 3 Minchkin Good Standing Member
Originally Posted by iminhell View Post
Yes the grind/lockout is a trans issue.
The syncro's can't match speed fast enough at high RPM. Using a lower viscosity fluid helps.
I run 5w-30 motor oil and shift without issue @8,000RPM.
The thinner fluid allows the syncro's to catch up faster, less resistance.
You use motor oil in your transmission? Color me confused... But I don't remember it having this issue before I asked my dealer to switch out the transmission fluid...
As for OP, did this answer any questions?
Originally Posted by Fact Core from Portal 2
Before the Wright Brothers invented the airplane, anyone wanting to fly anywhere was required to eat 200 pounds of helium.
SES #032
Minchkin is offline
