Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - If I will buy a new Ford Focus which engine?
Old 10-05-2012, 06:06 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,110, Level 100
Points: 33,110, Level: 100 Points: 33,110, Level: 100 Points: 33,110, Level: 100
Forum Activity 65%
Activity: 65% Activity: 65% Activity: 65%
I dunno, I think Canada is not under CARB- LOL.
The PZEV, 03-04 Duratec, was available in all states if someone ordered it, but required in "green" areas. After 05, all Focis are Duratecs, but only the ST has the 2.3L engine. One of the known problems might actually help you out. There is an issue with the "tumble flaps" which are in the plastic intake manifold. These were put in there by Ford to increase low end torque and efficiency. The flaps flip down partially blocking the intake plenum, and increasing air velocity at low rpm. At high rpm, the flaps open up to allow more air in. Over time, the bushings wear out, and the tumble flaps rattle. It sounds like horrendous valve noise, but it's not. You can determine if it's tumble flaps or valve noise by using a mechanic's stethoscope trick with a screwdriver. I did it on my car, the valve cover was silent (aside of the whirring you'd expect)- the intake manifold was not! For a long time, I thought it was the valves- and I've been working on cars for a very long time. I even had a friend who is still racing listen to it- he thought it was valves. If someone without this knowledge was driving this car, they might be scared, take it to a mechanic, and it might not ever get repaired. They they would want to sell the car.
To fix it, you need a new intake manifold, but it's not super duper serious. I've been driving my car with bad tumble flaps now for like 20k miles or more. Lots of people think it's merely injector noise, so there are probably Focis out there with more miles on bad tumble flaps than mine.
There is no timing belt on this engine, it's a chain. The oil is very easy to change, the filter is beside the oil pan at the front of the engine compartment.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
