Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - sporadic's Turbo Duratec build #2
Old 10-05-2012, 08:01 AM   #78
sutyak
sutyak's Avatar
Fan#: 12724
What I Drive: Turbo 04 DSG Mach 1
Points 15,704, Level 80
Points: 15,704, Level: 80 Points: 15,704, Level: 80 Points: 15,704, Level: 80
Level Up 71% Completed
FF Reputation: 62 sutyak Excellent Standing Member
Buy-Sell-Trade Rating: (16)
Originally Posted by Hughesy27 View Post
Checking in to see how the builds going?
Nothing going on at the moment. I still need to work on an insulator between the head and manifold, and also wrap the back and underside in reflective heat tape.
I did get a code thrown from removing the IMRC and leaving the flag set to o"1" in the tune. Out of frustration I just removed the IMRC from the stock intake and wired it up! I was in a rush and driving over 300 miles on-way so that's where it sits now. I have a couple lean spots in the tune, but none in WOT.
Right now it is set at 10-11psi, overall running fine and the meth injection is also fine. I need to get my slicks mounted and try to hit the track once this year before they close.
I have no more build plans for 2012 other than gathering parts for 2013. I still need rods, bearings, clutch/flywheel and diff. I'll play with the tune a bit more but that's all.
I do have a full set of poly suspension bushings I need to install at some point. I just hate messing with the pos rusted bolts on the rear suspension.
mark
'04 Mach 1. Built. Turbo. 667whp/631wtq
'06 Focus. Built. Turbo. WMI. (sold)
'03 Mach 1 : 12.61 @ 106.59 (sold)
sutyak is offline
