Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Shifting issues... Time for new or rebuilt tranny?
Old 10-04-2012, 08:57 PM   #1
thehypeisreal
Fan#: 102002
What I Drive: 2005 ZX5
FF Reputation: 1 thehypeisreal Good Standing Member
I've been having a problem with 5th and reverse. Both grind about 95% of the time just going into gear. Also have problems with the shifter popping out of these gears on its own once they are engaged. Its more noticable in 5th because I usually dont stay in reverse long enough for it to have the same problem. I did figure out I could get into reverse without grinding if I move the shifter into 4th first, then into reverse. Also noticed how loose and playful the shifter feels in pretty much all of the gears, moves side to side quite a bit, which just doesnt seem normal. So is there a simple fix for this or is it more of a major issue?
thehypeisreal is offline
