Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Timing Chain
Thread: Timing Chain
Old 10-04-2012, 04:55 PM   #38
SaleenT121
SaleenT121's Avatar
Fan#: 57997
What I Drive: 05 Saleen Focus
Points 3,489, Level 36
Points: 3,489, Level: 36 Points: 3,489, Level: 36 Points: 3,489, Level: 36
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
FF Reputation: 3 SaleenT121 Good Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by klrfoucs View Post
is changing the timing chain and lashing the valves a weekend garage mechanic type of job? ive changed many older ford and chevy v8 timing chains but never something this new.. im a little nervous to get into it then f something up... i have 104k on my 08 and i drive the piss out of it so im sure its needing one at this time. im guessing if i had it apart i could easily install cams as well?
You could do it in a weekend, get a book and map it out. The haynes manual doesn't tell you much though its only good for pictures. but you will need a need a new crankshaft bolt because its not keyed and u should not reuse the old one. I personally would not change the timing chain till about 200K, because its not a belt and the chains last a bit longer. I havent read a post yet about the newer foci jumping timing.
Saleen Focus #74
-Carbon Hood and trunk
-SVT rear Disc brake conversion
-Custom fab turbo kit
-Built 2.0L by Turbo Turtle
SaleenT121 is offline
