Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Can an armrest be put into a 07 Focus that was stock w/o one?
Old 10-04-2012, 02:57 PM   #5
sola fide
Fan#: 104515
What I Drive: 2007 Black Ford Focus
FF Reputation: 1 sola fide Good Standing Member
Originally Posted by rambleon84 View Post
iirc correctly you replace the entire section and not just the armrest portion. the only thing that stays is the ebrake and your shifter. (some one else will probably know for sure, im sure you arent the first to swap armrest.) There will be screws holding everthing in on the front cupholders and then the screw you already found on those rears. then you just unscrew your shift knob. the only tricky part is the e-brake, pull it all the way up and then lift everything over it(tight fit)
I went through armrest withdraw initially going from a car with one to the one with out. After driving with out it for a while and then driving my sisters focus with one, i preferred with out better. That center counsel portion is interchangeable from 00-07, havent heard of anyone with issues with them not fitting (manual to manual, auto to auto of course.) Also, some people with manuals get annoyed with the arm rest, saying it gets in the way of the shifter and ebrake.
Also, your car sounds like a base S model. Manual and no power standard, AC was an option at that level. You will also not have a tachometer or ABS.
Thanks rambleon. This makes more sense and at least now I have an idea of what all I'm getting into. I'm guessing from what I see the section you're referring too only goes up past the shifter. It does not include the front face console with the radio and the AC controls, correct?
I've worked extensively on a 1990 mustang that I own and I've noticed even 17 years later some of the design and layout is the same. A while back I had to pull the middle console over the E-brake on that one and it was a pain.
Thanks again.
sola fide is offline
