Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 3000 RPM/70 MPH Engine Drone
Old 10-04-2012, 02:38 PM   #4
Fan#: 104195
What I Drive: 2006 Focus ZX4 SE
Points 296, Level 5
Points: 296, Level: 5 Points: 296, Level: 5 Points: 296, Level: 5
Level Up 92% Completed
FF Reputation: 1 Vegoose Good Standing Member
Originally Posted by S0C0nFused View Post
Also, Are you inferring a sympathetic harmonic, or just the exhaust note/volume?
I would say it sounds more like a harmonic. At lower mph, but the same engine RPM, the sound is not as loud. I've check out the exhaust system and cant see any obvious leaks. The car has spent its entire life in Las Vegas so rust/corrosion isn't an issue.
I also noticed that small bumps cause the noise to go away for a moment, which is making me wonder if the motor mount is the issue. Maybe when I hit a bump it allows the engine to rise up in the passenger side mount and the noise is reduced?
Vegoose is offline
