Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Think I figured out the shuddering when starting from a stop...can't believe it
Old 10-04-2012, 12:59 PM   #93
noahsfocus
noahsfocus's Avatar
Fan#: 90974
What I Drive: 2015 White ST3
Points 534, Level 10
Points: 534, Level: 10 Points: 534, Level: 10 Points: 534, Level: 10
Level Up 68% Completed
FF Reputation: 5 noahsfocus Good Standing Member
Originally Posted by pozi240 View Post
You definately should get your dealer to check out your DCT as per TSB 11-12-13, have a read of my findings today from my dealer:
http://www.focusfanatics.com/forum/s...=1#post4387008
Great write up ...this means there is hope for a fix. So just because no leak can be seen from the outside of the bellhousing doesn't mean an internal leak hasn't contaminated the clutches causing damage and all the shuddering issues. So we should have our clutch packs pulled and inspected and not just the outer bellhousing inspected. Wonder how hard it will be to convince the service dept to do this? Your post helps and I'm sure will be used by many to get this looked at.
noahsfocus is offline
