Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Think I figured out the shuddering when starting from a stop...can't believe it
Old 10-04-2012, 12:23 PM   #89
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 5,996, Level 50
Points: 5,996, Level: 50 Points: 5,996, Level: 50 Points: 5,996, Level: 50
Level Up 23% Completed
FF Reputation: 1 raptor1956 Good Standing Member
Originally Posted by pozi240 View Post
You definately should get your dealer to check out your DCT as per TSB 11-12-13, have a read of my findings today from my dealer:
http://www.focusfanatics.com/forum/s...=1#post4387008
Your linked post is very informative and makes sense. I have a later build date (5/7/12) and do not have any DCT problems and turning off TCS did nothing for me, but those that have an earlier build date are much more likely to have bad seals and if the oil gets on the clutch pack all bets are off as far as drive-ability. TCS may induce or worsen the shudder problem on a car with contaminated clutch packs by adding another variable in the control loop that isn't "tuned" to handle the unexpected torque/speed response between the input and output of the transmission.
What I'd like to see is a few more of you with the problem bring your car in to have the seals and clutch packs checked and if a significant percentage of you with the shudder issue wind up having contaminated clutch packs that would put to bed the issue and put the onus on Ford to make good on this to ALL there customers with the problem.
It may well be the case that just about all these issues can be traced to bad seals and contaminated clutch packs.
Brian
2012 FF Ti HB Sonic Blue, Built 5/7/12, 401A + Parking Technology Package and MFT w/NAV 3.0.2 -> 3.2.2 -> 3.5.1 -> 3.6.2
raptor1956 is offline
