Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - No Heat After Coolant Flush
Old 10-04-2012, 01:16 PM   #16
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 29,448, Level 99
Points: 29,448, Level: 99 Points: 29,448, Level: 99 Points: 29,448, Level: 99
Level Up 67% Completed
Level up: 67% Level up: 67% Level up: 67%
Forum Activity 100%
Don't know for sure.
From your prev. post I'm guessing it's the yellow E.L. you mentioned, and that should be a non-silicate type that would be equivalent.
Haven't heard of issues from mixing those types in different brands, as opposed to many stories (including Trucking industry articles and car magazine articles) of problems from mixing between green silicate types, E.L. coolants, and the GM orange coolant. Mixing between those types apparently can cause a gel like precipitant that can clog passages causing overheating.
Same type in different brands SHOULD be a non-issue, but with so many types available and labeling often being a bit confusing I try to avoid mixing at all - small amounts left from changing the entire system being unavoidable.
sailor is online now
