Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - No Heat After Coolant Flush
Old 10-04-2012, 10:41 AM   #13
diexodos
Fan#: 104141
What I Drive: 2001 Sand color Ford Focus ZTS
Points 295, Level 5
Points: 295, Level: 5 Points: 295, Level: 5 Points: 295, Level: 5
Level Up 90% Completed
FF Reputation: 1 diexodos Good Standing Member
Sailor, thanks for the coolant advice. For now, i will use Prestone yellow extended antifreeze ( available in my garage) with Wet Wetter additive. If everything works fine (no head gasket issue, good flow, no overheating, etc) I will switch over to Ford Gold after a year of running it with Prestone. The radiator reservoir has a thin layer of brown scum. How can i can get clean? Should I buy another reservoir?
diexodos is offline
