Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Hughesy's 2nd Gen Duratec Turbo Build
Old 10-04-2012, 10:22 AM   #189
Hughesy27
Hughesy27's Avatar
Fan#: 84331
What I Drive: 2010 blue se
Points 1,977, Level 26
Points: 1,977, Level: 26 Points: 1,977, Level: 26 Points: 1,977, Level: 26
Level Up 77% Completed
FF Reputation: 1 Hughesy27 Good Standing Member
Definitely makes sense. Well the car is being a pain. Have to do another log for the tune I have. I load the tune I'm sent and do the log, 3 min idle, 3 min cruise, 3rd wot. Able to do the log fine but about 10 min down the road it will max out lean and start shaking while cruising under 3k at partial throttle. So I talked to Tom about it and gonna get a longer datalog to see what's going on. We are going to pick back up on Friday and tune all day as well as Saturday if needed. I've looked over everything and double checked all the lines and hoses. Switched out the injector connectors for the ones sporadic sent with the injectors I bought from him. Just in case the ones I had on there where coming loose or arcing while I was driving. Not sure what's going on but we will get it figured out.
Sent from my Nexus 7 using FF Mobile
Hughesy27 is offline
