Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Source needed for 2.3 Oil Pan Gasket
Old 10-03-2012, 11:13 PM   #8
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,952, Level 94
Points: 23,952, Level: 94 Points: 23,952, Level: 94 Points: 23,952, Level: 94
Level Up 61% Completed
Forum Activity 98%
Activity: 98% Activity: 98% Activity: 98%
FF Reputation: 79 felixthecat Excellent Standing Member
yes there is some vibes at idle only= but its well worth it.
Originally Posted by DueceCoupe View Post
Excellent,all Help is appreciated Guys.
Did You notice a lot more vibration with the BSD?
Is anyone running the BSD with aftermarket mounts or cams?
Rep added for all who helped.
I have a set of crane cam's, udp's, fwerks header, & a vf engineering dogbone. So w/ those mods on the motor, yes they is some vibes at idle only & it's totalley no issue at all. It's well worth it. And your motor w/ hold anothor 1.5qtrs of oil too. I use a FL842 filter also= shorter then a 400 but has a bigger diameter. Basicy freer up the motor & removes 14lbs of rotating & 18lbs of static weight.
felixthecat is offline
