Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - No Heat After Coolant Flush
Old 10-03-2012, 02:22 PM   #7
diexodos
Fan#: 104141
What I Drive: 2001 Sand color Ford Focus ZTS
Points 295, Level 5
Points: 295, Level: 5 Points: 295, Level: 5 Points: 295, Level: 5
Level Up 90% Completed
FF Reputation: 1 diexodos Good Standing Member
Back flushing the heater core and replacement of hoses is the first step. Is there a vendor that sells all hoses as a package deal? I see a total of six hoses that need to be purchased: two hoses to the heater core, an upper hose to the radiator, a lower radiator hose and two hoses to the reservoir.
When do you know that the thermostat housing needs replacement? Should I spray dish washing fluid and look for bubbles? Also, as I said on an earlier email, the thermostat is removed for now until I am done flushing it. But I have used the thermostat gasket to provide a seal and minimize leaks. Without the gasket it leaks crazy. Is it possible that the gasket by itself does not provide a good enough seal for the thermostat housing? I see on the internet the presence of two gaskets, a large one for the thermostat seal and a small round one. Where does the small round gasket connect to?
The reservoir has lots of crop in it. It is hard to clean the inside. I can see replacing it too.
Trying to keep the cooling cost restoration under a $200 budget since other maintenance areas need fixing. Any cost saving ideas, such as vendors and stuff are welcome.
diexodos is offline
