Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Think I figured out the shuddering when starting from a stop...can't believe it
Old 10-03-2012, 09:28 AM   #9
PratoN
PratoN's Avatar
Fan#: 88058
What I Drive: 2012 Kona Blue Ti Hatchback, DCT
Points 4,690, Level 43
Points: 4,690, Level: 43 Points: 4,690, Level: 43 Points: 4,690, Level: 43
Level Up 70% Completed
FF Reputation: 19 PratoN Great Standing Member
Originally Posted by gkirk View Post
Could it be that with the wheel+tire combo you have, your call falls outside the diameter of wheel that the TC is expecting? My understanding is that the car expects a certain number of revolutions at a given speed, and if its not getting that number, the TC will start doing things.
I had a similar problem with my bimmer's traction control bc i had wheel+tires that were a bit too big (speedometer was off too).
It's just a thought.
Edit: Also the most recent flash for the DCT was also for the ABS/traction control. So maybe there is something at issue there.
Good point that the latest flash affected ABS, I forgot about that. I'll have to try this, but I doubt it'll solve my issue.
Also, I don't think the wheel size has much to do with TC/ABS as long as all of the wheels are the same size since it's checking for tires slipping and not revolutions vs true speed.
I could see lighter/heavier wheels causing issues if it's outside of the car's expected loads / parameters... that said, I think we're experiencing a leaking clutch seal (internal, most likely, since I have no fluids outside my bell housing as of yet).
2012 FF Ti HB Kona Blue, DCT, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at v3.8 157k miles and counting...
PratoN is offline
