Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Hatchback door rattling
Old 10-03-2012, 07:47 AM   #18
nseah
Fan#: 101824
What I Drive: 2012 Sterling Grey Ford Focus SEL
FF Reputation: 1 nseah Good Standing Member
Originally Posted by sbc17 View Post
You have to put foam or felt around the perimeter of the door panel to remove the vibration. The plastic door panel vibrates on the door sheet metal. The speakers just amplify the vibration making it more noticeable.
There are (5) T25 torx bits in the front door.
1 behind the reflector
1 behind the release handle
1 behind the upper right corner of the door under the little cover
2 behind the trim piece at the door handle
The rear door has 3 torxs screws also T25.
2 under the door handle.
I believe there are 6 clips holding on each door panel. To remove the door pull from the top of the door hard and quick. If you pull slowly you will end up bending the plastic panel to much and create the "whiting" effect on parts of the door. It seems counter intuitive but this is the best way to do it.
As for the foam, this stuff would probably work the best:
http://www.amazon.com/gp/aw/d/B001H4...dir_mdp_mobile
Put the foam flush with the inner edge of the panel(so you don't see it).
If done correctly this should end your buzzing.
Hope this helps guys.
Let me know if you have anymore questions.
-sbc
Thanks for your help. I will try this if Ford doesn't do anything
-Nate
2012 Sterling Grey Ford Focus SEL Hatchback
nseah is offline
